cccccccc
Jun 14, 2020Aspirant
Orbi regular FTTC internet drop outs
Regular internet drop outs. Comes right after a while eg 5 minutes, or if I restart the power to the NBN box and router.
No logged outages at Aussie Broadband when they put a trace on.
All lights ok on NBN FTTC box.
When I “kick connection” from Aussie Broadband App and re seat Ethernet connection in NBN box service is resumed with a 10 seconds or so.
Using Aussie Broadband BYO basic settings.
Latest firmware.
Wifi connection is not lost
Latest firmware.
Is the ISP modem in router mode or modem only mode?
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopCan the ISP router be removed?
Try the Orbi in AP mode with the ISP router.
- ccccccccAspirantFTTC NBN box is directly connected to ORBI, no ISP Modem/Router in between.
Any other ideas?- michaelkenwardGuru - Experienced User
cccccccc wrote:
FTTC NBN box is directly connected to ORBI, no ISP Modem/Router in between.The FTTC NBN box IS the modem.
cccccccc wrote:
Any other ideas?Not without useful information.
Is there any reason why you are keeping its details a secret?
If you don't want to answer questions, then just search this community for stuff on NBN. It is a constant theme. Someone has probably been down the same road already.
Search - NETGEAR Communities – NBN FTTC box
Then there is this:
What is an NBN network and is my NETGEAR DSL modem router compatible? | Answer | NETGEAR Support
cccccccc wrote:
All lights ok on NBN FTTC box.FURRYe38 has already set you on the right track. If you need more help, tell people what this box is. There seem to be a heck of a lot of different boxes.
The ISP may also be important. Some NBN Internet service providers go out of their way to make life difficult for people. Is that Aussie Broadband?
Here's a good place to start looking for local help:
