Jarredd
Jun 17, 2019Aspirant
Orbi Router Able to access cPanel for 1 of my website, but not the other
Hello!
I have a couple of websites being hosted through inmotionhosting.com and have WordPress installed on them. On one website I can access the cPanel just fine through the backend. The other website I recently (last Monday or Tuesday) changed the primary domain on and since then, the cPanel does not work unless I type it in directly; I can no longer use the backend link. I have spent a few hours attempting to resolve this with inmotion's tech support. They say it is a local issue. The 2083 port is not blocked by my ISP, and it works just fine for one URL, but not the other.
The backend link works if I am on another network (a separate wifi or my phone). It even works, at times, if I reset my Orbi router, but then it eventually stops working. I receive the error that the server is taking too long to respond. I do not have any firewalls currently enabled. I have not set up anything beyond the basics on the router. This does appear to be a local network issue, but for the life of me, I cannot figure out what's going on.
- I receive this error whether I am using Google Chrome, Microsoft Edge, Safari.
- I receive the error on both my PC (just did a fresh restore on it, have not installed any firewall/BitDefender) running Windows 10 and on my Macbook Pro.
- I receive the error on both my Samsung Galaxy S9+ and iPhone 6s, both will load the link if on their 4G plan, but not if going through my home wifi network.
- I can login to cpanel if I go to mydomain.com/cpanel
Router: RBR50 Orbi AC3000
Router Firmware Version: V2.3.1.60
Here is a link that should be working to even pull up the cPanel login page: https://secure256.inmotionhosting.com:2083/login/
Here is a screenshot of what I receive: https://prnt.sc/o2xagf
I've only had the router since March 10th, just outside of the 90 days for me to contact Netgear's tech support.
Any thoughts would be appreciated.
I just noticed the modem you are using is a 4G LTE Modem. The default setting for this is router mode so unless you set the Orbi into AP mode you will have double NAT and the root of your problem. You can confirm this by connecting your PC directly to the modem (unplugging the Orbi).
Log into the modem and set it for Bridge Mode.
Is the Orbi system operating in Router or AP mode?- JarreddAspirant
Hello!
Thank you so much. My Orbi system is setup in router mode with one satellite.
As stated in my original post for my Orbi setup,Router: RBR50 Orbi AC3000
The modem being used is also a Netgear. Model: LB1120
I want to confirm that this all works with other domains I own, it's just a problem with this one.I found out tonight that I can also not load webmail. I receive the same sort of errors, even on other ports. I'm not sure if there is an issue with the router and the specific server, but this is a recent problem. It doesn't make any sense that there is a problem with just the one domain. Ugh!
- Talk2MikeApprentice
What DNS servers are you using? If set to an ISP's servers I suggest you log into your Orbi and change it to another server, such as Google Public DNS (8.8.8.8 and 8.8.4.4), OpenDNS (208.67.222.222 and 208.67.220.220), Cloudflare (1.1.1.1 and 1.0.0.1), etc.
