mgdurand1's avatar
mgdurand1
Luminary
Dec 02, 2017
Orbi Satellite and Cat 5 connector - printer?
Hi.  Gave an Orbi system to a good friend.  Solved their network range problems.  However, they tell me that the wireless connection to an Epson printer seems to shut down regularly requiring a reboot of the printer a few times to resstablish connectivity.  To me that sounds like a printer issue as opposed to an Orbi issue.  But I am not there to troubleshoot.  They live out of town.  My question is, can I have them connect the printer via a Cat 5 cable to a satellite?  What more would be required to get that printer on the network and visible to other remote computers?  Never tried that but just a thought.  will keep looking online but thought I'd ask here.  Thanks.
  • Does the printer even have a wired LAN connection? If it doesn't, then the answer is obvious. If it does, then I guess it would work. I can't promise that there won't be some issues with the Orbi, but the manufacturer probably wouldn't have put an ethernet connector on there if it weren't usable.
    • mgdurand1's avatar
      mgdurand1
      Luminary
      Yes.  It has a wired LAN connection.  Every network printer I have ever seen has one.  Do you know of one that does not?  I'd be curious to know.  I also think it will work but was wondering if anyone had tried it and had it actually work.
      • loomis1975's avatar
        loomis1975
        Luminary
        I have a new HP Envy Photo 7155 network that does not have an ethernet port, wifi only. There are a lot of them now.  If you hook them up directly to a computer via USB, you lose a lot of functionality.  I have to reboot it once every week or two, as it eventually looses its wifi connection (wifi blue light on printer blinks).
