ileodo
Mar 30, 2020Tutor
Orbi Satellite Drop Connection time to time
Hi, For some reason, my RBS50 Orbi Satellite dropped connection couple times a day. The synptoms are: 1. all the devices conntected to RBS50 Satellite dropped the connection (both Wireless a...
Apr 09, 2020Guru - Experienced User
Let us know the results of removing the switch between the RBR and RBS. The RBS will connect correctly and will be seen in the UI. This points to a switch problem and rules out a FW issue. FW doesn't matter in this case.
https://community.netgear.com/t5/Orbi/Orbi-MR-2-1-Update-3-23-18/m-p/1553749/highlight/true#M30673
https://community.netgear.com/t5/Orbi/switching-requirements-for-ethernet-backhaul/m-p/1653718/highlight/true#M43817
https://community.netgear.com/t5/Orbi/Ready-to-chuck-this-system-through-the-window/m-p/1658470/highlight/false#M44394
Your switch is a managed switch:
https://www.netgear.com/support/product/GS108Ev3.aspx#docs
Need to disable all IGMP protocols and green ethernet features on this switch, then see connect it between the RBR and RBS. If the problem continues, find you a non managed switch with out these features. I think NGs GS105 will work. I use D-Link DGS105-108s and HP Procurve 1400 series switches that do work with Orbi.
ileodo wrote:seem like no, I'll give it a try now, and see if any process restared on satellite.
however, as per netgear official website, it's a valid setup to have both router and satellite connected to a swtich to have ethernet backhaul.. why it doesn't work well in my case?
Retired_Member
Apr 09, 2020
FURRYe38 wrote:FW doesn't matter in this case.
V2.5.1.8 firmware does matter
