Theodam77's avatar
Theodam77
Orbi Satellite Firmware update
Hi there,
I have read several options to get the firmware uptodate. Having installed router and satellite very quickly. Great!
However, I get the message "page not found" when I want to go to advanced on my page at orbilogin. What is wrong? I cannot check if I do have the latest firmware.
So, what to do in order to:
a, check the version of firmware (and how to knwo what is the latest)
b. update the thing automatically?
Thank you
Theo
  • I would request a more detailed release note for newer frmware.
    Thank you
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Theodam77
    Have you tried to use 192.168.1.1 to log into the orbi GUI?
    DarrenM
    • Theodam77's avatar
      Theodam77
      just did, nothing
      maybe I did something wrong.
      I used the address in the google search.
      • DarrenM's avatar
        DarrenM
        You should be typing that in the URL bar at the top of your web browser. Also make sure the device you are on is connected to orbi network it could be on another router or if you are on a phone it could be on the cell network
        DarrenM
