Theodam77
Jun 26, 2017Aspirant
Orbi Satellite Firmware update
Hi there, I have read several options to get the firmware uptodate. Having installed router and satellite very quickly. Great! However, I get the message "page not found" when I want to go to...
DarrenM
Jun 28, 2017Sr. NETGEAR Moderator
You should be typing that in the URL bar at the top of your web browser. Also make sure the device you are on is connected to orbi network it could be on another router or if you are on a phone it could be on the cell network
DarrenM
Theodam77
Jun 29, 2017Aspirant
Thanks, that is what I did. Orby was connected. Nothing happened.
DarrenM wrote:You should be typing that in the URL bar at the top of your web browser. Also make sure the device you are on is connected to orbi network it could be on another router or if you are on a phone it could be on the cell network
DarrenM
- DarrenMJun 29, 2017Sr. NETGEAR Moderator
Have you tried to do this on another device in the home?
DarrenM
