flamenca
Sep 24, 2018Tutor
Orbi satellite flashing and not pulsing white
I bought another Orbi RBS 50 to work with my existing system. I have an existing Orbi router and one satellite and wanted to extend the WiFI system in my house. As soon as I connected the new Orbi satellite it began to flash white instead of pulsing white. It proved impossible to connect to the router. Any suggestions would be gratefully received. I am no tech wizard so basic advice would be appreciated.
FW on the new satellite needs to be updated first:
https://kb.netgear.com/31573/How-do-I-manually-upgrade-firmware-on-my-Orbi-Satellite
- flamencaTutor
Thank you for your prompt response. No problem downloading the information to update the firmware for the new satellite but as it has not connected to the router when I go to manual update it will only display the original satellite Orbi. I note that the new satellite Orbi is running on V1.12.0.18 and my system is running on V2.1.4.16 but how do I get the firmware to update when it willnot display.
You'll need to manually download the FW update files to your PC.
