Katamai
Apr 30, 2018Follower
Orbi satellite losing connection every few hours - Magenta circle
Every few hours, for no apparent reason, my Orbi satelite gets the magenta LED, i lose connection for a few mins and then it reconnects as if nothing happened. I live in a relatively small 74 sqm app...
Apr 30, 2018Guru - Experienced User
If you have small size home, then you may only need just the Orbi router. Satellites need a good 30-40 feet between the router and satellite to start. Try using the Orbi router only and test. The router can cover a good range by itself.
