gjs28
Nov 10, 2017Tutor
Orbi satellite manual firmware upgrades not working
When I try to manually update my satellites to install the hot patch, I can't log in to the satellites using the same login as my router. The boxes that pop up is http://192.168.1.3/fwUpdate.htm and ...
gjs28
Nov 13, 2017Tutor
I reset the satellites (holding the reset pin while power is connected), added them back to the network, and the password now match, so I was able to manually upgrade the FW.
