Nyfireman3097's avatar
Aug 20, 2017
Orbi satellite will not connect to my router
I set my orbi and satellite 2 days ago. It was fine then last night and all day today the satellite stopped working. I opened the app checked for satellites and none found. I try to connect it got the blue ring and nothing. I suck at computers for the most part so any advice would be huge. I have the few 12.0.18 on the router
  • Hello Nyfireman3097
    Do you happen to have a special character or space in your wireless password this is a known bug to make satellites disappear. If not you could try to factory reset the satellite and re sync the unit.
    DarrenM
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Nyfireman3097
    DarrenM
    • Nyfireman3097's avatar
      Nyfireman3097
      Thanks Darren I actually did I factory reset I and took the space out and it's working great thankfully 👊🏼
    • justSomeone's avatar
      justSomeone
      Wait... I missed the notice that a SPACE or special character is causing all this wonkiness with 12.x
      Why is this not an PINNED message at the top of the forum?
      • DarrenM's avatar
        DarrenM
        This issue will also be fixed in the upcoming firmware.
        DarrenM
