pmjoen's avatar
pmjoen
Orbi Satellite won't connect after power outage
Every time the power goes out, the satellite wont reconnect with base.  I have even plugged it in next to the router (litterally 1 inch away) still wont sync.  Then after a few days of trying to restart/resync it eventually does but no actions are different (light blinks white, then eventually stays magenta)...  Anyone have any ideas, there is really no troubleshooting steps past this?
Ive tried the following
Restarting (power cycle) both router and satellite and sync (no fix).
Restart (power cycle) only satellite and sync (no fix).
Performing sync multiple times (no fix).
Unplug satellite for a few days and perform the same above sometimes it resolves.
I refuse to pay for support after paying a ton of money for this mesh system...
  • FURRYe38's avatar
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
    Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
    Try a factory reset on the RBS then re-add it to the RBR...
    • pmjoen's avatar
      pmjoen
      RBR50 Orbi Router>RBS50 Orbi Satellite
      Firmware for both:
      v2.3.1.44
      Xfinity/TG1682G
      2400sq ft Distance betwen router and satellite 15 feet (but ive had same issue with them an inch apart)
      • FURRYe38's avatar
        What mode is your modem operating in? Router or Modem only? This is a modem/router combo unit:
        This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
        Couple of options,
        1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
        2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ or IP Pass-Through for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
        3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
        15 feet is too close between the RBR and RBS. 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
        You can also try upgrading FW to v60 as well if the factory reset on the RBS doesn't resolve this.
        Firmware for both:
        v2.3.1.44
        Xfinity/TG1682G
  • Just curious, how is "sync" performed?
    For example, is it sync'ed via pressing the black button in the back or something other method?
    • pmjoen's avatar
      pmjoen
      Per the instructions of Netgear, select the "Sync" button on Router, and within 2 minutes select "Sync" on Satellite.
      • SW_'s avatar
        SW_
        Prodigy
        Ah, I see.
        Pressing the 'sync' button might not clear the stale or corrupted configs in the Satellite as a result of power outage. You might want to force your Satellite to refresh its config instead.  If you can't even login into your Satellite UI page after power outage, you might consider going all in, find a paper clip and Factory Reset the Satellite, which should be quicker than waiting for a couple days for the cached/stale configs to expire.
        If you can login to your Satellite, please check out this earlier post on how to refresh your Satellite configs.
  • I'm having a similar issue and have done the full factory reset but it only lasts for a short period of time (maybe a day or two).  I'm starting to wonder if power outages fried something.
    • FURRYe38's avatar
      Is the Orbi system operating in Router or AP mode?
      Is Beamforming, WMM and Daisy chain enabled or disabled?
