russellmoran99
Nov 24, 2016Luminary
ORBI Satellites
I have ORBI Router and 2 Satellites. (6,000 square for home). I am noticing that certain things disconnect. My nest cams for one are going offline a lot. I have just recently disabled beaming after re...
peteytesting
Nov 24, 2016Hero
russellmoran99 wrote:
. During this troubleshooting I noticed the satellites appear to be getting new IP addresses assigned to them a lot. I have noticed at least 4-5 IP changes.
2 Questions...
Why are they changing so often?
If I make them static, will that cause any issues?
sounds like the sat is too far away from the router if its dropping the connection and aquiring a new ip address
i have mine set as 192.168.1.2 and 192.168.1.3 ewserved in the dhcp reserved client list
if that is what you mean by stattic ip addressing and its fine
