Jemill00's avatar
Jemill00
Orbi Secure Device Connection
I've been using my RBR50 and Satellite for several months and suddenly a couple devices stopped connecting to the secure side of the router. My Honeywell thermostat and Furbo (dog camera/treat launcher) lost connection and both will only connect to the open, guest wifi networks.  I didn't change any settings on the devices or router.  Both are 2,4GHz only.  I have found no other devices are having issues.
Any ideas/help is appreciated.
  • Firmware is V2.7.1.60 and was just upgraded after the issue started.  It did fix it.
    I have engaged the Furbo support and the advised me to separate the 2.4 and 5GHz channels to connect directly to 2.4,
    Thanks
  • FURRYe38's avatar
    Was FW updated recently?
    I would contact the Mfr of these devices for additional help and information regarding there products.
    • Jemill00's avatar
      Jemill00
      Thanks
