RayFinkel's avatar
RayFinkel
Orbi Speedtest reports 900mbps, but PS4 connection via LAN is poor
Okay, so I use Optimum as my ISP, and I pay for 1 GB internet. I have a Netgear Nighthawk CM1200 as my modem, and Orbi as my mesh network (RBR50 as my router, and 2 satellites). I work and game from the 3rd floor, so I can understand if the speed and connectivity via wi-fi isn't always perfect up there. However, I've even brought my PS4 right next to the router and modem, plugged in via ethernet (cat6) into the router, and I'm still only getting like 100mbps up (10-20 down). I've tried all the different LAN settings (Cloudflare DNS), opening up the recommended ports that PS recommends, etc. The Orbi speed test says I'm getting 900mbps+, but the PS4 is nowhere close to that. My phone and laptops all get much higher than my ps4 even via wifi (300-500mbps).
I'm at my wits' end at this point. I'm clearly getting the speed from the ISP, the modem is passing that speed to the router if the speedtest is reading at 900+. The PS4 is lightly used and has no issue with overheating or anything like that. I'm at a loss. Please help!!!
  • CrimpOn's avatar
    CrimpOn
    Can you try different Ethernet cables between PS4 and Router?
    Also, look closely at the actual Ethernet jacks on the PS4 and Router.  Do all 8 tiny gold wires inside the jack look correct?
    Is there any other 'wired' device that can be connected?  (laptop? desktop?)
    • RayFinkel's avatar
      RayFinkel
      Thank you for your reply! It is a good cable (new) Cat6 with gold tip. Same results when I use the Cat5 I have laying around 😕
      Do you know of any issues specifically between Orbi and PS4? I am really at a loss...
  • FURRYe38's avatar
    Do other wired PCs or Laptops get near 900Mpbs while connected at the RBR?
    What does the connect rate link speed show on the RBRs web page under Advanced tab/Show Statistics for the PS when connected to the RBR?
    Armor, Smart Parental Controls or Circle, Traffic Meter.
  • CrimpOn's avatar
    CrimpOn
    The PS4 indeed has a gigabit Ethernet port:
    https://www.playstation.com/en-us/ps4/tech-specs/
    I have checked Optimum  gigabit, and cannot find the "up" speed that is promised.  Customers focus primarily on the "down" speed because that affects performance the most.
    The reason I ask is that speeds "just under 100Mbps", such as 94-96, are usually an indication that two devices have auto negotiated a connection rate of 100Mbps?   As FURRYe38 indicated, this would be shown on the Orbi web interface, Advanced Tab, in the Blue Show Statistics box.
    https://en.wikipedia.org/wiki/Autonegotiation
    The reason for this is almost always the cable connection, either the cable itself or the jack/plug connections.  i.e. a bent wire or a poor crimp on the cable.  Even a brand new cable can be faulty.
    Of course, if the speed reported is over 100Mbps, then this cannot be the case.
