s22tran
Sep 20, 2017Aspirant
Orbi SSID not appearing
I have an Orbi RBK50. When I turn on my router and satelite, the SSID does not appear on my network list. The pin hole reset button is initially unresponsive as well and after a while (more than 5 minutes later) I am able to use it to reset with no change in the SSID apperaring.
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello s22tran
Are you able to log into the orbi using the ethernet cable and change the SSID?
DarrenM
