s22tran
Sep 20, 2017Aspirant
Orbi white light blinks for 30 mins before I can see SSID on network list
Everytime my orbi router turns on and then off again it takes 30 mins before I can see the SSID on network list again. The white light blinks for 30 mins before it turns solid white and then I can see the SSID on the network list after 30 mins. Any ideas? I'm using the 1.12.0.18 firmware.
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello s22tran
You may want to load the latest firmware onto you unit and try a factory reset after could be a bad setting happening in your unit.
https://community.netgear.com/t5/Orbi/OrbiOS-2-0-availability/m-p/1368730#M13446
DarrenM
