gjayw's avatar
gjayw
Orbi Wi-Fi Turning Off
Noticed over the past month that the Wi-fi from the orbi is momentarily switching off & on, all devices loose the signal then pick it up again, anyone else had this issue and if so how did you resolve it?
  • FURRYe38's avatar
    Nobody else reporting anything like this.
    Any other wifi nieghbors near by? if so, how many?
    Try changing to manual channel 1, 6 or 11.
    What FW version are you using?
    Distance between satellite(s) and router? Feet?
    • gjayw's avatar
      gjayw
      No new neighbors, carried out an RF survey(I’m a network engineer with access to some handy tools) no difference when the Chanels are changed and no interference showing yet all 18 devices lose connectivity for a short period of time, irrespective of whether they are connected to the main orbi or the satellite unit, pretty sure this is an issue with the main orbi
      • FURRYe38's avatar
    • gjayw's avatar
      gjayw
      Already tried changing to channels 1, 6 or 11.
      What FW version are you using? V2.1.4.16
      Distance between satellite(s) and router? Feet? - 40ft
  • FURRYe38's avatar
    Has a full reboot of the system been performed.
    Try disabling Daisy Chain, Mimo and Fast Roaming..
    I would do as last resort, factory erase and set up from scratch...
