pmoutzo's avatar
pmoutzo
Orbi wifi speed has degraded because of firmware 2.5.1.8 on satellite?
First time posting on this forum...after some Googling I figured I would come here and see if anyone had some suggestions. (The google is recommending many confusing and conflicting things to resolve my issue)
Here is what I know, I have Xfinity Gigspeed and have been able to run consistant speed tests using the Orbi iPhone app. I get about 540 Mps down and 43 Mps up. I understand this is the speed the Orbi router achieves because its sitting directly connected to the xFi modem from Comcast. This Orbi router is running firmware V2.3.5.30. My one satelite is running v 2.5.1.8.
Speed tests from my iPhone, iPad, laptop, whatever...via wifi is only reaching 25mb down. The satellite running a different firmware is what I am pegging as the issue. I have never changed any configs and the backhaul between the router and the sat is actually wired. I don't have Circle or any of that other stuff either. I can't figure out what has changed all of a sudden, but wifi degredation for me and the entire quarantined family is noticable today.
Has anyone seen this behavior before? I am not even sure how only one device got updated firmware while another (the router) hasn't. The ioS app is showing that I still have to do an update and I've tried to do the iOS update many times. I have rebooted and power cycled these devices multiple times (as well as the Comcast box)
I'm looking for some help here before I go and try to figure out a direct-connect (via ethernet) to the satellite to roll back the firmware upgrade.
Any help is appreciated
P
  • Retired_Member's avatar
    Retired_Member
    you're best bet is to stay away from  v 2.5.1.8.  Lots of folks report problems
      Retired_Member
      your better bet is to STOP manual firmware updates all together.
  • FURRYe38's avatar
    There is newer FW available for both RBR and RBS.
    https://community.netgear.com/t5/Orbi/RBR50-RBS50-Firmware-2-5-1-16-Update/m-p/1897955/highlight/true#M89460
    Manually download and unpack the FW files. Manually install them using a wired PC and web browser. Manual FW upates is preferred over using auto FW updates.
    P
    • smeg36's avatar
      smeg36
      Initiate
      I am having the exact same problem here. I came to the community looking to ask the same question if I couldn't find an existing thread. I just started noticing the degredating when a class I was teaching over Zoom started cutting in and out. Speed tests from the iOS app show around 900Mbps down 42Mbps up. But any device connected wirelessly get around 10Mbps. The link rate on the Macbook I'm on now sitting 10 feet from the router is 54Mbps. I was on firmware 2.5.1.8 on both the router and satellite for the past while, so I upgraded it to 2.1.5.16 on both. I guess I'm going to try downgrading now.
        Retired_Member
        revert your firmware and STOP performing manual firmware updates
