pmoutzo
Apr 22, 2020Aspirant
Orbi wifi speed has degraded because of firmware 2.5.1.8 on satellite?
First time posting on this forum...after some Googling I figured I would come here and see if anyone had some suggestions. (The google is recommending many confusing and conflicting things to resolve...
Apr 23, 2020Guru - Experienced User
There is newer FW available for both RBR and RBS.
Manually download and unpack the FW files. Manually install them using a wired PC and web browser. Manual FW upates is preferred over using auto FW updates.
pmoutzo wrote:First time posting on this forum...after some Googling I figured I would come here and see if anyone had some suggestions. (The google is recommending many confusing and conflicting things to resolve my issue)
Here is what I know, I have Xfinity Gigspeed and have been able to run consistant speed tests using the Orbi iPhone app. I get about 540 Mps down and 43 Mps up. I understand this is the speed the Orbi router achieves because its sitting directly connected to the xFi modem from Comcast. This Orbi router is running firmware V2.3.5.30. My one satelite is running v 2.5.1.8.
Speed tests from my iPhone, iPad, laptop, whatever...via wifi is only reaching 25mb down. The satellite running a different firmware is what I am pegging as the issue. I have never changed any configs and the backhaul between the router and the sat is actually wired. I don't have Circle or any of that other stuff either. I can't figure out what has changed all of a sudden, but wifi degredation for me and the entire quarantined family is noticable today.
Has anyone seen this behavior before? I am not even sure how only one device got updated firmware while another (the router) hasn't. The ioS app is showing that I still have to do an update and I've tried to do the iOS update many times. I have rebooted and power cycled these devices multiple times (as well as the Comcast box)
I'm looking for some help here before I go and try to figure out a direct-connect (via ethernet) to the satellite to roll back the firmware upgrade.
Any help is appreciated
P
- smeg36Apr 23, 2020Initiate
I am having the exact same problem here. I came to the community looking to ask the same question if I couldn't find an existing thread. I just started noticing the degredating when a class I was teaching over Zoom started cutting in and out. Speed tests from the iOS app show around 900Mbps down 42Mbps up. But any device connected wirelessly get around 10Mbps. The link rate on the Macbook I'm on now sitting 10 feet from the router is 54Mbps. I was on firmware 2.5.1.8 on both the router and satellite for the past while, so I upgraded it to 2.1.5.16 on both. I guess I'm going to try downgrading now.
- Retired_MemberApr 23, 2020
revert your firmware and STOP performing manual firmware updates
smeg36 wrote:I guess I'm going to try downgrading now.
smart decision
when your system NEEDS an update NG will push it to you. you don't have to do a thing
- FURRYe38Apr 23, 2020Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).Above suggestions working:
https://community.netgear.com/t5/Orbi/Throttling-Devices-RBK53/m-p/1858561/highlight/true#M81925
https://community.netgear.com/t5/Orbi/Orbi-Satellite-Drop-Connection-time-to-time/m-p/1890341/highlight/true#M88026Has a factory reset and setup from scratch been performed since last update? I would suggest this if this has not been done yet.
Also there is newer FW available as well:
Due to more and more people working from home, there maybe some ISP issues seen as well. ISP are getting loaded down sometimes.
smeg36 wrote:I am having the exact same problem here. I came to the community looking to ask the same question if I couldn't find an existing thread. I just started noticing the degredating when a class I was teaching over Zoom started cutting in and out. Speed tests from the iOS app show around 900Mbps down 42Mbps up. But any device connected wirelessly get around 10Mbps. The link rate on the Macbook I'm on now sitting 10 feet from the router is 54Mbps. I was on firmware 2.5.1.8 on both the router and satellite for the past while, so I upgraded it to 2.1.5.16 on both. I guess I'm going to try downgrading now.
