peltolivier
Dec 10, 2016Follower
Orbi WiFi System
hi,
I want to install my orbi but i have a router and modem in 1 so do I need to buy a separate modem or not?
1 Reply
hi
it depends on how you want to run it all and how your internet is connected
you can ether bridge the modem/ router you have so it works as a modem only and connect the orbi system behind it running as a router and connecting to the isp
or
leave the modem / router as it is and connect the orbi behind it and run the orbi system in ap mode
