Paiatz's avatar
Paiatz
Guide
Jun 06, 2017
Orbi WiFi System
Hello all,
i have a ORBI RBK50 system and i want to connect Reolink Argus Wire-Free Cam´s to it.
This Cameras are working only with 2.4 mHz. Why is this not possible ?
regard
R.Pojeti
    Try unchecking "Enable 20/40 MHz Coexistence" under Advanced, Advanced Setup, Wireless Settings, in the Orbi GUI.
    There's a chance that might allow your 2.4 GHz device to connect.
    • Paiatz's avatar
      Paiatz
      Guide
      after  electricity issue i lost the connection to my cam´s (2,4 GHz) i tryed to check and uncheck "Enable 20/40 MHz Coexistence" but nothing helps. the CAM´s are niot able to find the ORBI Wlan..any suggestions what i can do ??
      • st_shaw's avatar
        st_shaw
        Master
        I suspect the problem is related to the latest firmware.  I can no longer connect to one 2.4G device that I could connect to on the last firware.  Changing the coexistence setting has no effect.
  • You might also try turning on the Guest Network if that doesn't work, I had a 2.4 Ghz device that wouldn't connect via the regular 2.4 Ghz channel but had no problem on the Guest Network.
