marcdev81's avatar
marcdev81
Initiate
Aug 26, 2017
Orbi with Spectrum Modem/Router
Spectrum installed my internet and they use a 2 in 1 cable modem/router. How do i set it up for my orbi to work?
  • You can run Orbi in AP mode.
    Or, if the Spectrum router can be put into Bridged Mode, you can do that and run Orbi in Router mode.
    • marcdev81's avatar
      marcdev81
      Initiate
      If i run spectrum as a bridge mode. Does that affect the modem part? I only have 1 box functioning both as the modem and router
      • st_shaw's avatar
        st_shaw
        Master
        No. The purpose of bridged mode is to disable the router while leaving the modem enabled.
        I dont know know if the Spectrum box includes bridged mode though. You'll need to determine that via Google or by contacting your ISP.
