stoosh98
Jul 22, 2018Aspirant
Orbi won't reach garden room
Hi,
I bought a RBK50 setup but putting the satelite in the garden room is just out of range. I have a wired connection to it, but was hoping the Orbi would reach so that I could have the simpli...
Sagz
Oct 24, 2018Aspirant
stoosh98 Did this work? Planning the same for my future mancave in the garden.
- stoosh98Oct 24, 2018Aspirant
This weekend I put the orbi satelite back down there, wired. Yes it seems to be working but the app and the satelite LEDs would suggest it is not so great... The app sometimes shows no satelite, will show a green but mostly magenta connection. The Satelite had the magenta LED suggesting a weak connection. However, everything seems to be connected and working when I have tried, so i'm going to leave it as it is!
- SagzOct 24, 2018AspirantFingers crossed it stays that way. Thanks
- FURRYe38Oct 25, 2018Guru - Experienced User
What version of FW are you currently using?
Be aware of this: If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-and-connection-problems-Skybell/m-p/1649275/highlight/true#M43001
