robstoneley's avatar
robstoneley
Initiate
Sep 28, 2018
Orbi WPS and Canon MG7570
My Canon MG7570 printer is unable to pick-up any signal from my Orbi router.  I have pressed the Sync button on the Orbi and then had my printer attempt to connect but it has failed each time I have tried.  The printer picks up wireless signals from my neighbours' appartments but nothing in mine...  Any suggestions?  (I am not tech literate so any suggestions will need to be written for a dummy!).  thanks
  • thanks - after fumbling around and trying this solution I found elsewhere (set the 2,4 Ghz to Channel 10), I have got it working
  • FURRYe38's avatar
    What FW is currently loaded?
    MAKE SURE your printer FW is up to date. Some printers wifi isn't the greatest. Does the printer have a LAN port or just USB port?
    What security modes are you using on the Orbi? Try Disabling WPA temporarily on the Orbi. Then try to see if the printer will connect? If so, then try WPA and TPIK and test. Then try WPA2 and AES only and test.
    MIMO, Daisy Chain, Fast Roaming, IPv6. Save settings and reboot the router and satellite(s).
    • robstoneley's avatar
      robstoneley
      Initiate
      • FURRYe38's avatar
        Interesting. Seems to be a printer issue. Normal channels are 1, 6 or 11.
        Enjoy. :smileywink:
