ISST107's avatar
ISST107
Tutor
Feb 19, 2022
Orbilogin.com
I can easily login to orbilogin.com using my 2018 Macbook Air.  However, if I try with my new Macbook Pro M1 chip I am not able to login.  I tried all variations (e.g., orbilogin.net, 10.0.0.1, etc).  Any help would be appreciated.  Thanks
  • plemans's avatar
    what error is it giving you?
    did you try a different web browser?
    • ISST107's avatar
      ISST107
      Tutor
      Good morning.  There was no error message.  Tried numerous browsers and all do the same thing.  Just time out.  However, if I use my Macbook Air, works fine. Same operating system and same internet.  Also tried the othyer ways of logging in (e.g., 10.0.l0.0, 193...etc).  Carzy why it won't work on my new laptaop.  Only difference must be the Apple Chip?  Thanks
      • FURRYe38's avatar
        Try different browsers on the M1?
        What OSX versions are you using?
