studdawg's avatar
studdawg
OrbiLogin requiring contant authentication
For the last couple of months, the web login from my desktop is useless.  I can login ok to the orbi but it then constantly asks to reauthenticate.  Most times it accepts the credentials but sometimes it doesn't and I have to give up.  It's made it so it is unusable.  Anyone else having this problem?
  • CrimpOn's avatar
    CrimpOn
    My experience is there are certain screens which pop up the user/password screen every five minutes or so (and other screens that do not).  The "Attached Devices" screen is the one that annoys me the most.  So, yes, I feel your pain.
  • plemans's avatar
    What firmware version are you on? (please don't say the latest)
    I know one of the versions had significant issues with this.
    If you're on the most current, try factory resetting it and reinstalling.
    • studdawg's avatar
      studdawg
      yes, i believe it's the latest.  It's an RBR50.  Firmware is v2.3.5.30.  And i've also noticed a drop in range as well associated with this firmware.  So resetting will fix the firmware?
      • plemans's avatar
        Maybe. Its worth a shot.
        Have you tried any other web browsers to see if its an issue with your pc/browser?
  • FURRYe38's avatar
    Be sure to clear out ALL browser caches before entering into the routers web page. Clear caches then exit the browser then re-open the browser then log in.
    Has a factory reset and setup from scratch been performed since last update?
