Carlsvette's avatar
Carlsvette
ORBIRBR20 DOES NOT SUPPORT SPECTRUM 400MB
Spectrum states that my router will not support their streaming service. Why not?
  • Thanks! The modem is a “Spectrum” modem, model, CM Mac or MTA MAC, A4CFD2E425B. The router is hardwired by CAT6 to the monitor. Not sure about the 4K, as both pieces of equipment are 2 years old.
    • FURRYe38's avatar
      Spectrum” modem, model # please. Post a picture of the front and back of this modem.
      • Carlsvette's avatar
        Carlsvette
        Thanks for your assist. I’ve connected the Orbi through the Spectrum router to the modem. All works well. When I connected the Orbi as a stand-alone, it would not pair with the modem.
  • FURRYe38's avatar
    First of all what brand and model# IP modem do you have?
    What kind of streaming services will they be using?
    Depending on connection, wireless devices may not be best for 4K streaming, however wired ethernet can support this.
    The Orbi 20 series is entry level system so not quite as speedy as others however should be well capable of supporting 400Mpbs on the wire.
