Matthew_struggl's avatar
Mar 23, 2020
Oribi won't connect to the internt
It won't let me have the RBR50v2 option but that is my model with one satellite.
I have used the app about 50 diffrent times and in 25 diffrent ways. I will open the app do excatly what it tells me to and then it will check the cables and then will say no internt connection. and I can connect to the internt and my phone and pc says there is no internet available.
If anyone has had the same problem and knows how to fix me I have rest it multiple times l. Also I will do anything and fix it
  • FURRYe38's avatar
    What is the Mfr and model# of the ISP modem the NG router is connected too? There a built in router here by chance?
    Matthew_struggl wrote:
    It has been going on for about 4 days and my modem is a chorus and it is very old I dont know a lot about it since it is about 5 years old
  • Retired_Member's avatar
    Retired_Member
    What model modem do you have?  How long has this been going?
    • Matthew_struggl's avatar
      Matthew_struggl
      It has been going on for about 4 days and my modem is a chorus and it is very old I dont know a lot about it since it is about 4ish years old but the thing is the modem is fine with all the other internt routers we have used but the orbi shows a stronger connection.
      • FURRYe38's avatar
