tivotron's avatar
tivotron
Playstation 4 not blocked
Long time reader, first time poster.  Thank you in advance.
Trying to pause internet connection to son's PS4.
I see the device in the Orbi device list, MAC address matches what I see on the device settings.
I click pause and it shows the device (PS4) is paused.
Still able to access the Internet.  :smileyfrustrated:
  • FURRYe38's avatar
    Are you using Orbi app to select the PS console?
    Do you have a IP address Reservation set up for this device ON the router?
    Is access controls enabled on the RBR?
    • tivotron's avatar
      tivotron
      First of all --- thank you!  Really love when a community comes together to help.
      Answers to your questions (and more questions):
      Yes, Orbi app on my phone.  I am able to successfully turn off the Internet to other wired & wireless devices on my home network.
      I do not.
      Where would I check this?  I am able to block other devices.
      • FURRYe38's avatar
        So the PS4 is the only one not being blocked when you disable internet for it while all other devices seem to be blocked for them correct?
        I do not.  Something to try. Under Advanced Tab/Setup/LAN Setup.
        Under Advanced Tab/Advanced/Security/Access Controls or Advanced Tab/Security/Access Controls I believe.
