noelisimo
Dec 11, 2016Aspirant
Plex Remote Access Configuration is not working on Orbi
I just replaced our R7000 router with Orbi Router and Satellite over the weekend. I noticed that it made our wifi faster but for some reasons when I start setting up the Plex for Remote Access, most ...
noelisimo
Dec 12, 2016Aspirant
Thank you kcsupra. I really appreciate it. :)
Will try that once I get home tonight and I will post it here later the outcome. Thank you again!
bsholbrook
Dec 15, 2016Apprentice
I have a mac mini running plex and did nothing in the router except check for UPNP being turned on (in fact i dont recall having to turn it on). ithe port forward approach will work, but you always risk the ip address of your plex services changing ips at which point things break. In my orbi config Orbi has automatically picked up on this....
UPnP: check advanced / advanced setup UPnP. If this isnt on turn it on. The router should pick up on the plex server and registered the upnp setting for the ports it is broadcasting with to accomodate. If UPnP is on and its not working check your plex preferences remote access setup. In plex my is automatically using the ports translated in UPnP, no manual settings. and again those line up with the orbi uPNP page.
I prefer to let features do what they are supposed to and not artificially insert hardcoding into the mix which will inevitably break as things change and will have long forgotten the specifics. port forwarding can break as your environment evolves. With a properly setup UPnP config plex should request router updates dynically. If that all checks out, there is a chance your "internet "modem" is interfering with UPnP, check that next. and then if all else fails use manual port forwarding.
