max14
Jul 20, 2020Aspirant
Port forwarding now working
Hi everybody,
I have the Orbi RBR50 running firmware V2.5.1.8 trying to forward a port.
My routers LAN address is 192.168.1.1 and the WAN address is 192.168.0.100.
The modem is set route mode and I am able to connect to the remote management page of the router.
The devices I'm trying to forward a port to are either a ip-camera or a webserver, both with a static ip, both not working.
If tried already forwarding different ports, internally and externally, showing no results.
If I connect to 192.168.0.100 I get connected with the right service (so either ip-camera or webserver) but nothing I seem to do effects my connection from the outside.
I've tried disabling Upnp, set NAT-filtering to open.
I would really appreciate, if somebody would be able to help because I'm pretty much stuck :)
Thank you very much in advanced
Probably due to your modem having a router built in already. This would be a double NAT (two router) condition which isn't recommended and would cause port forwarding to not work right on the Orbi router. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop - CrimpOnGuru - Experienced User
max14 wrote:I have the Orbi RBR50 running firmware V2.5.1.8 trying to forward a port.
This is the problem. The Orbi is connected to a router. That router will block all incomming connection attempts.
Netgear describes this as a Double NAT: https://kb.netgear.com/30186/What-is-Double-NAT
Nothing done on the Orbi will fix this. There are basically two alternatives:
- Place the Orbi in Access Point (AP) mode and learn how to configure port forwarding on the ISP router, or
- Place the ISP router into "bridge" mode (sometimes called "passthrough" mode).
I would start with a call to the ISP tech support and tell them, "Please put my router into bridge mode (and disable WiFi while you are at it).
