alokeprasad's avatar
Nov 28, 2020
Powerline PLP2000 wired backhaul for RBK50 or not?
Thinking of buying the RBK50 this season.
The office room has the cable modem and will have the RBK50 base router.  It will have one Powerline PLP2000 connected to the RBK50 base router (with PLP2000 outlets in other rooms for wired devices).  The Orbi RBK50 will add better signal mesh for non-wired devices.
Should I use a Powerline PLP2000 outlet in the remote location as the connection to the Orbi extenderunit? Or use the wireless connection between the base and extender units?
Thx.
Aloke
PS: I prefer wired connections whenever possible.I think that PLP2000 will provide better latency and reliable connection between the Orbi units.  Not sure about that, though...
  • plemans's avatar
    many things impact both powerline performance and wireless performance.
    What I'd do? try them both and see which one works better.
    We can't say 100% which will work better based off the details you gave.
    • alokeprasad's avatar
      alokeprasad
      Mentor
      Thanks for the reply.  You are correct that there's no way of knowing without trying it out.
      Can I set the satellite up for wired backhaul, test the speeds, and unplug the ethernet wire for it to switch to WiFi backhaul automatically?
      Or do each: wired, wireless backhaul: have to be set up individually?
      • plemans's avatar
        You should be able to.
        i used to frequently move my satellites around and some would be hardwired some wireless and didn't have to reinstall any of them.
