dagiam's avatar
dagiam
Powerline Satellite Magenta
hi guys, i have a Netgear RBK40 + Netgear RBS40.
everithing works fine until i try to add a powerline to the system.
when i plug a powerline to the satellite with the lan cable it works for 1 minute (more or less), i have connection.
after this minute, the satellite gets the magenta solid state color. connection lost and i have to disconnect the powerline from the satellite.
i did it for 5 times. it seems like the system doesn't allow me to add a powerline
can u help me?
thanks!
davide
    • dagiam's avatar
      dagiam
      i had already seen this..
      i need to understand why it is unable to obtain an IP address from your router or unable to your router after i plug the powerline..
  • FURRYe38's avatar
    You need to make sure the PL adapters are on the same IP address network as the RBR and RBS. Make sure the PL are working fully. These could be faulty.
    Check the RBS with a LAN patch cable between the RBR while near or in the same room as the RBR to check the status. Should say wired.
    What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
    can u help me?
    thanks!
    davide
  • CrimpOn's avatar
    CrimpOn
    I use Powerline to connect two Tivo units to my RBR50 router, specifically the TP-Link PA9020.  Connected like this:
    RBR50
     to
    8 port switch
      to
    Powerline
      to
    electric circuit----------------------------------------------------------------
                           to               to
                          Tivo             Tivo
    Works fine.  The Orbi has no idea there is a Powerline unit.  All it sees is ethernet.
    I have never connected Powerline to an Orbi satellite, but cannot imagine it would be any different.
    Do you sync the Powerline units before connecting to the Orbi?
