Rickd83
Nov 22, 2022Aspirant
Printer OFFLINE on ORBI, but IDLE on home network.
If my computer is on the home network, the printer shows IDLE. If the computer is on the ORBI network, the printer indicates OFFLINE. If I set my computer to ORBI network and reinstall the printer, the printer shows IDLE on ORBI and OFFLINE on the home network. Is there a way that the printer can work on both networks? Since ORBI is an extender of the home network, it seems there should be a way for the printer to work on both networks.
Sort By
What Orbi model do you have?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.- Rickd83Aspirant
Orbi Model RBR50
Firmware: V2.7.4.24
Router: Netgear Nighthawk Model CAX30
Rick
I recommend bridging the CAX30 modem if your going to use the Orbi system as a wifi mesh system.
Would help the printer maintain connection to the one wifi system.
Rickd83 wrote:If my computer is on the home network, the printer shows IDLE. If the computer is on the ORBI network, the printer indicates OFFLINE. If I set my computer to ORBI network and reinstall the printer, the printer shows IDLE on ORBI and OFFLINE on the home network. Is there a way that the printer can work on both networks? Since ORBI is an extender of the home network, it seems there should be a way for the printer to work on both networks.
How is your printer connected to your Orbi? Is wired, then make sure it is connected to your Orbi, not your home router.
Can you tell what the IP address is of the printer when it is installed from the home network vs. the Orbi network? I think we can learn a bit if we can examine the differences in the IP addresses.
- Rickd83Aspirant
The printer IP address for the home network is quite different from the printer IP address on the ORBI network.
Rick
