Toda922
Jul 06, 2019Aspirant
PS4 no longer connects to Orbi
Never posted here before so I don't know exactly where to start, so I'll just give all the details I can think of.
Model: I believe it's the Orbi AC3000 (RBR50) but not 100% positive. It was a 3-pack from Costco (1 router, 2 satellites).
Firmware: V2.3.1.60 (but should not be relevant).
Problem: PS4 no longer connects to Orbi after switching from Xfinity to AT&T (was fine Yesterday).
PS4 Error Codes: (PS4 error CE-37813-2 or CE-33991-5)
Full Context:
My household recently had AT&T Fiber 1000 installed and my PS4 is no longer connecting via WiFi or LAN to the Orbi Satellite in my room, which was NOT a problem with Xfinity. Now on my PS4 I "Set Up Internet Connection" then choose "Use Wi-Fi" or "Use a LAN Cable" then choose "Easy" setup...it then randomly asks if I want to use a Proxy Server (which never happened before). Obviously I press "Do Not Use", which makes my PS4 check the network environment only to then be greeted by the Error Code CE-37813-2. Believe me, I've tried manually setting up the connection using different DNS/IP/MTU settings. I also reset my PS4 and Orbi several times. And I even changed the router network name and password...but nothing works.
The strange thing is that my PS4 actually connects directly to the main modem network (whereas Orbi is the router network). I did other tests with AT&T Fiber and everything else connects to it just fine...it's only my PS4 that no longer connects. This makes me think that problem is with my Orbi and not with my PS4 or AT&T Fiber. Keep in mind, the Orbi's have not moved an inch since we first installed them 2 years ago and we factory reset them when we switched to AT&T. The ONLY hardware that's different after the switch is obviously the Modem which is now from AT&T.
So my questions are:
1. Is Orbi fully compatible with AT&T Fiber?
2. Is something about my Orbi no longer allowing my PS4 to connect?
3. What is going on??
What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router here already? If so,
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop- Toda922Aspirant
Not too familiar with Wi-Fi jargon so I'll answer to the best of my ability.
The modem AT&T provided is an ARRIS BGW210**. I believe it is a modem/router (see link below) so your assumption of Double NAT is probably correct. The Orbi is currently connected to the Arris via ethernet, so yes, we have 2 Wi-Fi networks across the house, one for the Orbi and one for the Modem. This is a similar setup as before with Xfinity. The Orbi was connected to the Xfinity modem/router, but that never caused any problems with my PS4.
I'm going to try doing the 3 things you recommended, however, I'm not that familiar with it so I'll probably need to contact customer support to walk me through it.
** I think this is the same ISP modem on Amazon (https://www.amazon.com/BGW210-700-802-11b-Wireless-Gateway-REQUIRED/dp/B07BZC72TB)
- Toda922Aspirant
Ok so I just called AT&T tech support and I believe they attempted the first 2 solutions (IP Passthrough and Bridging the modem) but neither worked. At one point, my PS4 even stopped connecting to the Modem Wi-Fi Network, but it never connected to the Orbi Wi-Fi or LAN networks.
A lot of people end up in the same boat because they have a modem/router in front of an Orbi router. As you have found, this is a recipe for chaos.
The easiest way out is not to faff around with complicated settings but to use the mode that so designed specifically for this purpose.
Go into the controls for your Orbi and put it into wireless access point (AP) mode.
There is support for the Orbi WiFi System, including a manual, somewhere at the end of this link:
>>>> Orbi RBK50 | WiFi System | NETGEAR Support <<<<
See the section Use the Router as a WiFi Access Point.
