Brenkj
Feb 22, 2019Aspirant
Putting Modem in Bridge Mode for Orbi Installation
I just got my new Orbi RBK50, and I'm getting ready to install it. I've found instructions online for how to put my ATT-provided modem into "bridge mode", so that the Orbi will be the only device broadcasting a wifi signal. Should I do that before or after I install the Orbi?
Thanks.
- ekhalilMaster
Please do it before you start the Orbi setup.
Good luck! :)
Thanks.
Yes, before setting up the Orbi. There is a difference between the ATT modem "mode" and the ATT modem WiFi radios being on. It can be a router, but not provide WiFi. Most Orbi users prefer to do what you are doing: ATT in bridge mode, ATT radios off.
- Chuck_MMentor
Do that before installing.
And to be precise, you have a modem/router combination.Bridging it will turn off the router functions and pass through to the Orbi to handle routing.
Bridge it
Power off
Connect Orbi
Power on Modem, Orbi and PC
Set up (hard wired ethernet if possible)
Enjoy
- BrenkjAspirantThanks for the responses. I did all those steps, in that order, but the Orbi app is saying there is no internet connection, and that an Ethernet cable cannot be detected. Any advice?
Try setting up the Orbi first with a PC or laptop thats connected to the Orbi router.
