ihateorbi
Aug 05, 2019Aspirant
R50 something
how you get it to stop giving you the incessant not found screen or asking me to login to every site i go to. this is some ridiculous cluster**bleep** of a product. (and one that has security added on to the product) i've never experienced anything like it and for 94 download for $600 is the worst decision i've ever made.
You could return the product? If you don't like it, you don't have to keep it.
There have been a number of posts about problems such as this, which have been resolved after providing information about the specific modem the Orbi is connected to and the specific devices which are having problems.
- ihateorbiAspirant
I can return the 2nd batch to Costco, but I'm still stuck with the first batch. Then what? This stuff is supposed to be plug and play. The instructions say so. Plug it in and it works.
- ekhalilMasterPlease do the following test:
Please open a Command Prompt on any computer attached to Orbi and type:
> tracert 8.8.8.8 (or traceroute 8.8.8.8 if you're using a Mac computer) and post the results so we can help you further.
- ekhalilMasterYes, Orbi is a great equipment if correctly set up.
The ISP modem and the way you connect the Orbi units together can affect the way Orbi functions.
Please provide more details about your setup so we can help you.
We are all here users of Orbi units and we have seen different issues, small and big, which we help each other to solve or find a workaround for!
