mcgunner's avatar
mcgunner
R8000 to ORBI RBR40
Have R8000 for personal activities with rbr40 connected. ORBI drooping signal and will not synch with satellite.
  • FURRYe38's avatar
    What FW is currently loaded?
    Is the R8000 wifi disabled? I presume the Orbi is running in AP mode?
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
    MIMO, Daisy Chain, Fast Roaming, IPv6. Save settings and reboot the router and satellite(s).
    • mcgunner's avatar
      mcgunner
      What is FW?
      Modem is Arris SB8200 (owned).
      Yes. R8000 wifi disabled. Don't know if the Orbi is running in AP (?) mode. How do I find out?
      House is approx 1800 sq ft.
      Satellite is approx 25 ft from Orbi.
      Not tech savy regarding channels. How do I find out? Are you referring to the Orbi or Nighthawk?
      One wifi neighbor within 50 yards.
      How do I disable any of the things you are referring to? Are you referring to the Orbi or Nighthawk?
      I do know how to save and reboot.
      Thanks.
      • mcgunner's avatar
        mcgunner
        What is FW?
        Orbi is now running in AP mode.
        Disabled all of the things you referred to.
        I
