fade0508's avatar
fade0508
RB40 not working in AP mode with virgin HUB 3.0
Hi,
Apologies if this has been covered elsewhere but I could not find a thread that addresses the problem/challenge/issue.
I recently installed Virgin Media Hub 3.0 and to improve coverage I purchased RBS40. I followed the instructions:
1. reset the modem
2. put my hub 3.0 in modem mode
3. connected the orbi to hub 3.0 via the internet ports.
At this point in the installation process I was asked for a PPOE username and password (which I  was told by Virgin is my wifi username and password). It didn't work.
I then put my Hub 3.0 back in router mode, and setup my orbi router in AP mode. I suscessfully managed to connect the satelite. I can now get internet by connecting to my Orbi Router and satelite but the Hub 3.0 is still in router mode too (so I have two live routers!!!) but everytime I put the hub 3.0 back in modem mode the Orbi cannot connect to the internet.
I know I have royally fudged the installation and am hoping if anyone can guide me on getting the hub 3.0 working in modem mode and ORBI in AP mode.
Thank you!
    Thank you!
    If Orbi is in AP mode, then you must run your Hub 3.0 in router mode.  You need one of the two devices to act as a router.  Your choices are:
    Hub (Router mode) --> Orbi (AP mode)
    Hub (Modem mode) --> Orbi (Router mode)
    • fade0508's avatar
      fade0508
      Thank you! Is there a performance difference between the two setups?
      • st_shaw's avatar
        st_shaw
        Master
        I don't think so.  I run my Orbi in AP mode.  With recent firmware, wired connections through the Orbi "router" are limited to about 700 Mbps. Not sure if Router mode is any faster, but I doubt it.
  • FURRYe38's avatar
    Besure to use the DMZ on the ISP modem if you run the modem in router mode with the Orbi router in router mode. DMZ helps in this kind of double NAT configuration.
