Thisted
Aug 17, 2020Follower
RBK 13 password
Where do I locate password on the RBK10 router. I purchased the RBK13 system with two satellites. Instructions indicate that it is located on a label but the only label on the unit shows SN and MAC. Thank you in advance...
You can log into the device to access the ssid/password as well as change them.
https://kb.netgear.com/23439/How-do-I-change-my-NETGEAR-router-s-WiFi-password-or-network-name-SSID
- MstrbigMaster
The default user name is admin. The default password is password. The user name and password are case-sensitive.
To recover forgotten password:
- Launch your browser and go to my.netgear.com/registration/login.aspx
- Select the "Forgot your password?" option to access the "Reset your password" window.
- Submit the email address used when creating Orbi account.
- Fill other fields and click "RESET MY PASSWORD".
- Go to your email and open the link sent by NETGEAR Support.
- You should be redirected to the NETGEAR Change Your Password page.
- Enter a new password and click "Submit".
