routerks's avatar
Nov 18, 2020
RBK13 -Satellite disconnnecting frequently
Hi,
I have installed RBK13 couple of days back and one of the satellite is disconnecting regulalry . Once i click on sync in both router and satellite2 it is connecting, after some time it  is disconnecting.
Please suggest if any settings to be changed when it is idle for long time or to stop frequent disconnection.
Thanks,
Kiran
  • FURRYe38's avatar
    What happens if you swap locations with this 1 RBS with one of the other RBS?
    • routerks's avatar
      routerks
      Tutor
      Hi,
      Can you clarify what does changing the location of RBS . Do you want me to swtich the RBS.
      Thanks,
      Kiran
