TimD5000's avatar
TimD5000
RBK23 connecting to NBN Arris not working
Hi
I am trying to connect a new Orbi Netgear router to the NBN arris box.
My service provider is internode and it looks like they only want to support a few router brands of their choice.
Is it possible to configure the Orbi to make it connect.
  • Internode use VLAN tagging for their HFC NBN connections.
    You need to enable that and set it to VLAN2 for it to work.
    https://www.internode.on.net/support/guides/general_settings/
    HFC/FTTC: Ethernet WAN (with 802.1q VLAN 2)
    https://forums.whirlpool.net.au/archive/2758953
    (shouldn't need to do the mac cloning though)
    In the Orbi config -> Advanced Settings -> VLAN section and set the "Set VLAN by group" option for internet to VLAN ID 2.
    *note - you may need to update your firmware first.
    • TimD5000's avatar
      TimD5000
      Sorry for late response
      Model # is Arris CM
      Firm Ware is V2.3.5.30
      • michaelkenward's avatar
        michaelkenward
        TimD5000 wrote:
        Model # is Arris CM
        Not a lot of help. CM probably means cable modem. But Google shows a whole raft of CM model numbers.
        The full details could be important. Especially of your "CM" is also a router.
  • FURRYe38's avatar
    TimD5000 wrote:
    Hi
