DeividN1's avatar
Mar 30, 2021
RBK23 upload speeds in Router mode
Hi there,
Why Netgear mesh systems (like my RBK23) limits dramatically the upload speeds setting up as Router? if I use the system as AP, all works perfect, but in Router mode... I can't obtain speeds over 250Mbps in a 600/600 line. I have try all but I cant solve it. I have the last firmware.
Anybody with the same problem?...
Thanks in advance.
  • plemans's avatar
    Make sure qos, traffic monitoring, parental controls, and access controls are disabled and reboot the router. those can sometimes decrease speeds.
    • DeividN1's avatar
      DeividN1
      Tutor
      Thx for your reply, all this services are disabled, but how can I check if QoS is off? I've read in some site that QoS is default off, it's true?
    • DeividN1's avatar
      DeividN1
      Tutor
      The ISP modem, is a HGU from Movistar/O2, the typical Mitrastar mounted by this corp like this one:
      The modem is in bridge mode and all weight of network is over the Orbi RBR, I have single NAT.
      • plemans's avatar
        Photos have to be approved by a moderator.
        And it wouldn't be the first time an ISP supplied device didn't have a properly functioning bridge mode/passthrough mode.
