johnny5126
Apr 16, 2018Aspirant
RBK30 purple?
Plug in satellite synced and everything seems to be working The router shows the satellite is connected, and back haul status is good. But the router is lit up purple, satellite has no light.lit. ...
Apr 16, 2018Guru - Experienced User
Did the happen before or after you connnected the satellite?
What is the Mfr and model # of the ISP modem your using with the Orbi system?
What FW are you using?
johnny5126
Firmware is the latest for both.
