craig83
Aug 02, 2019Aspirant
RBK33 Not updating IOS apps
I recently installed the RBK33 Orbi with satelites. Connected great and getting good speed and coverage. However, apps are not updating and when trying to install new ios apps they do not download.
This is happening across multiples ios devices.
I have updated the firmware through the orbi app.
I would try using a different dns provider than the one your isp uses if you have that selected within the orbi setup. you can try the google dns servers at 8.8.8.8 or 8.8.4.4
see if this helps.
Is the Orbi system operating in Router or AP mode?Do other internet apps work?
- craig83Aspirant
Netgear Cable Modem CM500
I am not sure which mode it is in. Just did a norml install. I have not messed with any of its settings (Orbi)
see if this helps.
