borborygmus's avatar
borborygmus
RBK43 Orbi Router and 2 x Satellites, Tri-Band AC2200 - extra satellite required
I have had this sytem for a couple of years now, has worked great in our old house. Now moving to a bigger house and I expect that I may need another satellite - which model should I buy to give me good compatibility? Or, has the technology improved so much that I should just scrap these and go for a whole new system? My existing house and my new house are both 200+ year old stone rambling buildings, so it has never been an easy challenge to get good wifi everywhere. TIA.
  • FURRYe38's avatar
    You can get a RBS20, RBW30, RBS50, RBS50Y out door satellite. Also EX7500, 7700 nad 8000 working as well in a pinch as extenders with Orbi AC
    • borborygmus's avatar
      borborygmus
      Thank you for the prompt reply. Oh, I'll definitely try my existing kit first. I am just pre-empting this discussion in case.
      • FURRYe38's avatar
        If yoru system is working for you and all your devices and it works in the new home, I would keep it. Unless you don't have any wifi devices that don't support AX, I wouldn't see a real need to scrap what you have and go for something different.
