dja2k's avatar
dja2k
RBK43S-100NAS Signal and Connected Devices
Hi I am new to this forum and had a few questions on my RBK43S-100NAS system I just got at Best Buy.  I have it setup already, speed is decent, but the network map shows satelites with poor reception.  I have Spectrum Internet with 200mbps and the farthest satellite gets average 80-90mbps wifi which is better than what i expected.  The RBR40 Router and 1st RBS20 Satellite is about 45 ft appart, then the 2nd RBS20 Satellite is about 40 ft appart.
System is running the latest firmware that updated when I ran the initial setup. The Satelites once synced glow blue, so I don't know ecactly what is going on there.  Can the system still work with Satelites being in poor reception mode without problems?
I have close to 30 devices, not all streaming i.e. things like Amason Alexa, Google Home, Nest Cameras, Mobile Phones, Xbox One X, Desktop PC etc. This Orbi system is rated for Internet Service of 200mbps (current Spectrum 200mbps Package), though what is this specification of 20+ device maximum?
Would I have to upgrade to RBK53S-100NAS for improving the sync between Router and Satelites?  Also the RBK53S-100NAS I belive is rated for more devices in the specifications at least.
I couldn't find the exact model in the drop down box of creating this thread, close enough though.  Any feedback is much appriciated.  Thanks!
  • I would try the new FW. Load the RBS first then RBR lastly, factory reset and setup from scratch. All will be on the same version of FW.
  • FURRYe38's avatar
    30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
    • dja2k's avatar
      dja2k
      Thanks for the replies.  The Arris Cable modem is connected directly to the Orbi Router, so that doesn't matter here.  By the way a little background info, I am coming from a dual Netgear R7000 setup that was hard wired to reach the whole area, but didn't quite cut it to the further end of hte house averaging 30-40mbps.  The Orbi 3 Sat system is an improvement giving me close to 90mbps at that same spot.  The Orbi RBR40 connection to the 1st Orbi RBS20 is flawless giving me close to 200mbps.  The drop speed I getting is from the 1st RBS20 backhaul to the 2nd RBS20, though there isn't wifi problems, drops, etc.
      I am not using Auto on the Wifi channels and I have used the wifi analyzer tool to set it to Channel 6 on 2.4ghz (3 people on this band) and 48 5ghz (only 1 on this band).  Beamforming has been enabled from the start and MIMO has been keep disabled cause some devices didn't like it.
      Armor & Circle are disabled, but Daisy Chain has to be enabled cause I have it Router>Sat>Sat setup. IPv6 has never been enabled.  Also 20/40mhz Coeistance can't be set to 40mhz only, I just have the option to disable or enable that.
      • FURRYe38's avatar
        What is the model# of the Internet Service Providers modem/ONT the NG router is connected too? Some modems have built in routers and wifi, so this needs to be checked is all.
        "Also 20/40mhz Coeistance can't be set to 40mhz only, I just have the option to disable or enable that." If you take th check mark out of the check box next to this setting, this sets 40Mhz only.
