darrenkdean
Jun 27, 2018Tutor
RBK50 - Backhaul Status Poor, After Firmware Update 2.1.4.16
Just installed a "new" Netgear Factory Refurbished Orbi & Satellite at our beach condo's (Amazon). Before I jump in, I have three sets of Orbi's in three locations & am a long time advanced user of Orbi systems.
Got everything setup out of the box. Orbi router in our primary condo, satellite, in the condo next door. Backhaul connection status was Good. Believe the firmware that came installed might have been 2.1.1.12. After everything was configured & confirmed working, I upgraded it to 2.1.4.16. Since then, the Backhaul Status (Wireless) is showing as poor. I've tried powercycling & re-synch'ing the devices but the backhaul status remains unchanged. The location/positioning/environment has not changed since initial setup.
Daisy Chain, Beamforming, MU-MIMO, & Fast Roaming are all enabled.
Any thoughts here? Anyone experiencing the same issue or know how to fix it? My other Orbi systems required some TLC in the beginning but have been running stable & fast for awhile now. I know this one can too, just have to get the config/sequence right.
Best-
Darren
Whats the distance between the router and satellite? 30 feet to start depending upon building materials.
What channels are you using? Auto? Try manual 1, 6 or 11 on 2.4Ghz.
Any wifi neighbors near by? If so, how many?
Disable MIMO, Daisy Chain and Fast Roaming, save settings and reboot both router and satellite.
- The distance between the Orbi & the satellite is roughly 50 to 60 feet (horizontally).
- The two condo units are next door to each other.
- Both the Orbi & the satellite are located on top of the entertainment centers in the living room, near the sliding glass doors that lead out to the deck/ocean.
- The units are located on the 18th floor & the only WiFi network is the 4esort wireless network.
- Building materials are concrete & steel reinforce (hurricane proof) towers.
- 2.4 Ghz Auto (8)
- 5.0 Ghz (48)
Will try disabling the additional features. I'm guessing that I'll have to factory reset & rebuild to fix it. Just don't want to jump through the hoops of resetting if there is another way.
Best-
Darren
Try manual channel 1, 6 or 11. Not Auto. Channel 8 shouldn't be used and not sure why the router is picking that.
50-60 feet is a bit of a distance between two living places next to each other. Anychance you can get them moved closer? Close the gap by about 10-15 feet. Not sure of the building materials as well...this maybe reason why your seeing poor status...
Well, run it for now and see how it goes. Good Luck.
- Nyirishman1877Aspirant
Ever since i update to fimrware V2.3.1.48. I keep losing internet connection on my router and satellites at 9pm each night. IS there anything I can do to prevent this from constantly happening?
Lets keep posting in your forum thread so we can keep the information all gathered in the same place:
https://community.netgear.com/t5/Orbi/ORBI/m-p/1742211#M60260
Thank you.
