p15353's avatar
p15353
Initiate
Feb 25, 2020
RBK50 and Vodafone Gigabox
Hi there
I have just ordered a RBK50 (its on its way) to install with my Vodafone Gigabox
However, I have been advised that VOIP service I have will ONLY run when connected to the Gigabox
Someone advised I can just leave my VOIP plugged into the Gigabox router and put the ORBI in AP mode
Hoever, I want the Orbi for parental controils on the wifi and I believe doing so will disable this feature
Can anyone please help a newbie like me ...please
Thanks
Declan
  • FURRYe38's avatar
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
    Try option #2 if your modem has a DMZ or IP pass thru so you can run the Orbi in router mode and keep the features needed.
    • p15353's avatar
      p15353
      Initiate
      Thank you
      Do i meed to turn off DCHP on the Gigabox to retain parental control;s etc on the Orbi , which yuou said to run in router mode? Note I need VOIP connetced to Gigabox
      • FURRYe38's avatar
        If the VoIP has to be connected to the Main ISP Gigabox, then you'll probably need to leave DHCP enabled there.
        What you might try is this, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
