Moneypit's avatar
Moneypit
RBK50 blocking sites
HI i have an RBK50 which seems to be blocking explicite URL sites, in particular my companies mailbox server.. I have disconnected the Orbi from my ISP CPE and connected directely through the ISP CPE after putting that back to router mode and I can connec no problems
As soon as I put the ISP CPE into Modem mode and connect it back to the orbi I have this issue. It used to work well.
If i connect using a VPN i can bypass the problem.. So i assume it must be the orbi..
I had to put the ISP CPE into modem mode as the back to back routers prevented my RIng security from working effectively
I am in the UK.. my setup is RBK50  + Sat  connected to Virgin media hub 3 (Aris TG2492LG-VM) setup as modem. Running both windows and MOS.
I have read on this forum, about adding the HTTPS to the blocking list with never blocking active, but this has not helped, unless i have configured this wrongly.
Can anyone offer any help on this issue.
Thanks
Pete
  • plemans's avatar
    Have you tried using the gateway in router mode and putting the orbi in access point mode?
    You loose some features on the orbi
    • Moneypit's avatar
      Moneypit
      HI I havent tried that but was under the impression i would loose my seamless roaming as we use the orbi to provide mobile coverage over wifi ..
      Was hopibg there was an explination as to why this just happened,,
      • plemans's avatar
        having the orbi in access point mode doesn't disable seamless roaming. It'd still work fine. It just doesn't integrate with the ISP cpe router's wireless.
        It could be a dns issue. Have you tried using googles at 8.8.8.8 or 8.8.4.4   or cloudfare at 1.1.1.1
